Ford Ranger Forums
Discussion Categories => Suspension Discussion => Topic started by: Dyllan on December 06, 2009, 10:15:14 PM
Title: Steering gear box?
Post by: Dyllan on December 06, 2009, 10:15:14 PM
Ok so has anyone else taken out there steering gear box?
I dont know what year they change the gear box, all i know is the ranger and the Bii had the same one in the 80's.
I was trying to take out the gear box, and the first thing i tried to do was disconnect both hydralic lines from the steering pump. One is on the right side (when looking into the engine compartment) held on with a threaded connection (bolt) the other is on the bottom, held on with a hose clamp.
I managed to turn the bolt at least a quarter turn, but it stopped and i couldnt get it off. So i moved on to the hose clamp, i had it held opened with vise grips, but i gould not get it off. I tried using a screw driver and a hammer, but it still wouldnt come off.
Does anyone know if im doing something wrong?
Title: Re: Steering gear box?
Post by: BADINTEN on December 07, 2009, 06:20:46 AM
i would have to see a pic
Post by: PlumCrazy on December 07, 2009, 11:09:19 AM
Both hoses are threaded into the gear box, the return line on the pump has a barb though.  Are you positive that you are looking at the gear box?
Post by: Dyllan on December 07, 2009, 08:22:06 PM
im taking off the hoses connecting to the steering pump.
Post by: PlumCrazy on December 07, 2009, 09:40:56 PM
the hose should just slip off the barb after you get the clamp slid down, but be careful using the hammer/ screw driver trick because the barb is plastic and will break off if you hit it too hard.  The threaded fitting on the side should unscrew, it just has an o-ring to seal it, so once it is broke loose it should come right out.  (you will need a flare nut wrench to break it loose without rounding it off)  If its already starting to round off then get a good bite with a pair of vise grips.
Post by: Dyllan on December 08, 2009, 04:30:27 PM
Great thanks.
Post by: rngrdanny22 on December 24, 2009, 12:52:45 AM
Were you ever able to get it off?
Post by: cvalcore on December 25, 2009, 03:16:48 PM
another trick to getting stuck hose's of after you take of the hose clamp is to grab on to it with a pair of channel locks right where the clamp was and twist it untile it breaks loose but be very carful if its a plastic fitting. And a hammer and screw drive is only going to cause damage and for the bolt if i remember right it should just screw all the way out.
Post by: Dyllan on December 26, 2009, 11:46:00 PM
Well i got the box out of the truck. the reason the bolt would turn and stop was because the hose was stuck and wouldnt turn separately. Now i am stuck i am unable to loosen the pitman arm nut to the steering box.
Post by: BADINTEN on December 27, 2009, 03:12:47 AM
i just used wd-40 and so elbow grease lol
Post by: PlumCrazy on December 27, 2009, 12:23:39 PM
WD-40 is lubricant, not a penitrating oil, so it may help after you break the nut loose but it wont do squat until get it turning.  PB Blaster and Sea Foam Deep Creep are some of the best penitrating oils out there.
Post by: BADINTEN on December 27, 2009, 10:48:49 PM
maybe you need to read it buddy it is also a penitrating oil and i have used it over and over again with no prob that and it smells way better than the rest lol. but i have been using pb blaster along time too
Post by: rngrdanny22 on December 27, 2009, 11:03:35 PM
The best thing for rusty nuts (LOL) is to use some kind of oil and use an impact wrench... I've snapped many bolts using the old elbow grease method...
Post by: BADINTEN on December 28, 2009, 12:07:02 AM
impact will do it too you have to penetrate it will some lube first lol
Post by: rngrdanny22 on December 28, 2009, 06:01:51 PM
LOL... it's hard to talk about this stuff without getting perverted.. haha
Post by: BADINTEN on December 28, 2009, 08:01:45 PM
lol i just put the words down its up to yalls mind to read it
Show Unread Posts
Show Unread Replies
